Can someone tell me how to take a DVD video clip and convert the music part into an MP3 file. Is this possible to do? Can it also be done with other video formats eg Mpeg video?
Cheers
Mike
Cheers
Mike
geposted Fri 02 Mar 07 @ 1:49 am
Do a google search.
There are softwares out for this
Dj Angel S
Dj Angel S
geposted Fri 02 Mar 07 @ 3:57 am
wow great thanks;)
geposted Fri 02 Mar 07 @ 5:26 am
I use IMToo's DVD Audio ripper to rip audio from DVD's. For divx files, I use Vdub.
geposted Fri 02 Mar 07 @ 6:08 am
I use ImToo MPEG Encoder ($35) for this But you should take a look at the ImToo DVD Ripper Platinum, it's their newest program and you can do a lot more things with your DVDs than just make MP3s.
I think it's like $45 but it's worth it.
Check it out:
http://www.imtoo.com/
Check it out:
geposted Fri 02 Mar 07 @ 9:22 am
