Can I do this effect in VirtualDJ to create a nice transition.
Save target as.
Hear/Download Effect
Thanks for any tipps.
Save target as.
geposted Fri 02 Mar 07 @ 8:16 pm
The effect is called "transforming"... well back when I used to do it in the 80s. One song is the accapella and the other is the instrumental. You can create the effect with a sharp crossfader or like I used to do way back when there wasn't such a thing... toggle your phono/ cd button back and forth or buy a "grandmasterflash" transformer effect box(good luck finding one).
In VDJ you can use the "Beat Grid" effect to do the same.
Funkmasterfrank
Montreal
Funkmasterfrank
Montreal
geposted Fri 02 Mar 07 @ 8:24 pm
Thanks for your reply funkmasterfrank, that is a good tip. I will try this. Well, the beat grid is a bit different, it does not do this cutting effect, which increases after time.
geposted Fri 02 Mar 07 @ 8:32 pm
