Topic: Broadcasting?
HeroyHome userMember since 2006
I'm having troubles.
i am connecting with port 7171, the port isTCP/UDP.
i am connecting with my IP.
when people to the url, they get a blank page, and a little download screen, which says save/open
when they save it, it doesnt save anywhere, when they hit open, hit doesnt open.
this is with VDJ 4.2 full version.
can someone help me?
geposted Fri 02 Mar 07 @ 9:52 pm
sbangsPRO InfinityMember since 2004
check this :)
geposted Sat 03 Mar 07 @ 12:28 am
"your connection is routed
so broadcasting ports are not accessible on the internet so you cannot stream from vdj as a local server
unless you go to your router config and forward port 8000
you will find instructions for this in your router manual
if you find this to confusing or you do not want to bother with this simply broadcast to an external server it will work fine :) "
i port fowarded to port 8000 to a UDP port type
now what is next?
geposted Sat 03 Mar 07 @ 10:33 pm
check this is unblocked on your firewalls aslo :)
geposted Sun 04 Mar 07 @ 12:56 am
Out of it for a while but I have a stupid question ; can the trial version of virtual dj broadcast over the internet if so how
geposted Sun 04 Mar 07 @ 9:06 pm
skyfxl wrote :
http://www.virtualdj.com/forums/59741/General_Discussion/The_Ultimate_Guide_to_Broadcasting_With_Virtual_Dj_).html
aye read this
geposted Sun 04 Mar 07 @ 9:12 pm
Are you even ment to broadcast with your IP? Theoratically only people in my network would be able to hear? And that is how it goes for me an automatically, it chooses my IP.. Yet choosing my WAN IP would make it work... How do i do so it chooses WAN instead of normal IP...?
geposted Fri 23 Mar 07 @ 9:15 pm
what you need to do is forward the ports to your wan ip. port 8000
geposted Fri 23 Mar 07 @ 9:28 pm
Thanks for the fast reply. However, I've forward the 8000 port now. What I need now is a way to get VirtualDJ to use my WAN IP, not my normal IP.. Is that even possible?
geposted Fri 23 Mar 07 @ 9:40 pm
Is that a hard one? :P
geposted Fri 23 Mar 07 @ 11:00 pm
Oh I was hoping u'd be as fast as you were before on the reply :S Shouldnt it use WAN ip in order for it to work (unless you wanna broadcast over your network)
geposted Fri 23 Mar 07 @ 11:55 pm
for an easyer setup i suggest you try a free external host like listen2myradio.com
i will look for a way to force wan
geposted Sat 24 Mar 07 @ 12:53 am
Thanks ^^ ALOT!! :D
And force wan thing would be cool if you find a way ^^
geposted Sat 24 Mar 07 @ 7:07 am
Okay, so now I've tried with listen2myradio.com. But it still doesnt work.. The connection doesnt seem to arrive to my router.
geposted Sat 24 Mar 07 @ 7:09 pm
geposted Sat 24 Mar 07 @ 7:21 pm
virtual dj 2.10 has not been availalable for 4 years
please use a legal copy .
http://www.virtualdj.com/download.html
cracked copies are full of bugs and one of these is that the broadcasting section is damaged.
hope to see you as a pro user soon.
geposted Sat 24 Mar 07 @ 8:54 pm
hahaha okay. yeah i think im gonna do that, unless ill be starting with the follow up program which i will get when i buy BCD 2000. Anyway I like VirtualDJ its easy and simple.. Thanks alot for your answers.
geposted Sat 24 Mar 07 @ 9:58 pm
