just a thought...
especially good for videos with breaks, like b.i.g.'s mo money mo problems
have a right click option for the cues
something like...
"default" and "jump to"(you can set a number of the cue where you want to jump to)
and give it a different color or something...
would save a lot of time editing videos... ;-)
i do it manually right now
have a cue at the beginning of the break and one at the end
i leave the cursor on the later one, in the song position window,
and click it when the former one reaches the middle of the waveform window
not perfect, but ok
p.s.: hate when even promo only's have breaks
something like...
not perfect, but ok
geposted Mon 12 Mar 07 @ 11:22 am
It's already available. Change skin and try again!
geposted Mon 12 Mar 07 @ 4:20 pm
are you sure ?
it will automatically skip the unwanted break part ?
which skin is it ?
are you sure ?
which skin is it ?
geposted Tue 13 Mar 07 @ 8:40 am
I may have misunderstood... but I can try to explain ;)
If you download skins like Mixstation, you'll be able to set many cue points and go there just by clicking on the button. You can also map a key on the keyboard with the action "goto_cue X", where X is the ID of the destination cue point, as it's the same command linked to the skin.
--- Update ---
Damn, it's manual :(
--- Update ---
geposted Tue 13 Mar 07 @ 10:44 pm
what happened to cels automated cue points?
geposted Wed 14 Mar 07 @ 12:48 am
I dunno... Haven't tried since version 4.x yet...
geposted Wed 14 Mar 07 @ 4:16 pm
