Forum: Old versions
Topic: XP10 mapper
Although the XP10 mapper almost speaks for itself there is no documentatiom or help file about the usage of the mapper.
For example you can select more function for a button with shift+1 ,shift+2 and shift1+2, but..... what does it mean ?
pressing shift on the keyboard and then the button doesnt have any effect. This is the only function atm I would like to clear out, since I cant figure it out myself :\
Wouldnt it be an idea to place a help file within the members section??
geposted Thu 02 Sep 04 @ 4:47 pm
if you press shift1 on the controller and them press play for example it allows you to assign another function to play while that shift key is being pressed, and yet another while shift 2 is being pressed. so effectivally you,ve just trippled the amount of shortcuts you can use for the XP10
Mmmm there aint no "shift" button here. Which fysical buttons are they or can they be mapped ?
ok found them.... it were the two buttons on the top-left on the controller (eject and playlist). these funtion as shift 1 and 2.
-topic closed-
