Has anyone else noticed when using an external HDD that there is slight lock up for a few seconds when loading a track onto one of the decks? Normally when playing I find that this isnt too much of a major problem, but I've found it significantly increases the time it takes to analyse an album.
Anyone know of any ways to speed this up? It doesn't affect the output of the music, just affects useability of the program for a few seconds. Anyone else noticed this? I dont think its a problem with VDJ, but rather with the transfere rate between my laptop and the external HDD
Nebula
Nebula
geposted Fri 16 Mar 07 @ 2:51 pm
it depends on the rpm of your harddrive the faster it spins the faster the files load
geposted Fri 16 Mar 07 @ 3:33 pm
yeah thought it might be something along those lines. thanks skyfxl :o)
geposted Fri 16 Mar 07 @ 3:35 pm
I'm just in the middle of setting up external hard drive for Video gigs. My research I found you can get external HDs with Serial ATA connection, and a card to match for your laptop/pc. This would give you the fastest throughput speed.
geposted Tue 20 Mar 07 @ 8:20 pm
Read my ranting and raving.
http://www.virtualdj.com/forums/66948/General_Discussion/Im_Ticked_Off__.html
geposted Wed 21 Mar 07 @ 5:06 am
Another thing that you have to keep in mind is that the more data you have stored in the HDD, the slower it gets, or at least, that's what I've noticed, for example, I have a 250 Gb IOMEGA External HDD and when I had about 75 Gb. the speed was awesone, but now that I have over 200 Gb, the HDD has become slower and the songs take a bit more to load than before, not to the point of the Software to freeze, but it does get slower.
geposted Wed 21 Mar 07 @ 3:59 pm
Yeh Man, I have the same problem! I've had VDJ actually freeze on me loading songs from the external drive! But even if it doesnt completely freeze it still scares the shit outta me if I'm working in a club or doing a party or something!! People DO NOT take kindly to music stopping all of a sudden!! Especially the people paying you!!!
geposted Wed 21 Mar 07 @ 5:43 pm
I never had a problem. I have a 250g hd using 2.0usb and it's a slower hdd.
geposted Wed 21 Mar 07 @ 6:39 pm
I've got a 1/2 teraByte job, and it really slows down on video files and freezes sometimes on a top of the line shuttle!
geposted Wed 21 Mar 07 @ 9:26 pm
The more data you store, the more fragmented the data gets. People who are having slow load times should defrag their driver. You will see a difference in your load times.
geposted Thu 22 Mar 07 @ 2:34 am
yeah, never really thought about a defrag for some reason :os lol ah well will give it a try :o) thanks guys
geposted Thu 22 Mar 07 @ 2:13 pm
Pardon my typo above. I meant defragment your *drives*.
geposted Thu 22 Mar 07 @ 3:05 pm
Try using Firewire as opposed to USB 2.0, I experience a vast difference in performace since USB is controlled via software, Firewire is more hardware based control. I have a external that has both connections, and the Firewire is much faster to load songs, and no freezing in VDJ.
geposted Thu 22 Mar 07 @ 4:44 pm
thanks djbeware, will look into that. :o)
geposted Fri 23 Mar 07 @ 4:55 pm
With HDDs
Speed is important! 7200 is the only way to go if you are using VOBs,
USB 2.0 is good, Fire Wire is better.
Large external HDDs need to have a fast seek time and a high buffer size helps too.
Segate has a great 750gb, 7200rpm, 16mb buffer with a 5 year Warrantee for around $400.
it has a USB 2.0 & Fire Wire conection also has a Fire Wire connection so you can chain several drives together and only need 1 Fire Wire input on your computer.
I am using 2 of these drives linked and it's running smooth, but I also have a Kick A$$ computer to support it.
geposted Fri 23 Mar 07 @ 6:33 pm
