i need some help with your vdj database updater ...i have mailed you ....thanks
geposted Fri 03 Sep 04 @ 11:09 am
Can you ask your question in an english forum from now on since this is a french forum? Thanks :)
Ok here's an answer: if you use the MixMeister txt file, leave all settings AS THEY ARE and it should work properly. The default settings were chosen for a mixmeister file (tab-separated, path=1, bpm=4).
If you prefer to read the BPM infos from the mp3's, just choose "BPM's" from the main screen, and click "Update". This will read BPM info from the ID3Tag and add it to the VirtualDJ Database.
Hope this helps,
macourteau
P.S.: There is an FAQ about the updater in the plugins section that explains everything well:
http://www.virtualdj.com/forum/display.html?topic=5649
Hope this helps,
macourteau
geposted Fri 03 Sep 04 @ 11:22 am
