Is there a plugin that I could add text to the screen. Maybe to add the next singer's name or a special club promotion?
Also, What does this mean.... "It only works with VirtualDJ v4.x and Numark Cue"? I have v4 but not numark cue. What is that?
geposted Mon 19 Mar 07 @ 1:25 pm
This tells you for which version of VirtualDJ is each plugin / skin.
http://www.numark.com/products/product_view.php?v=overview&n=171" rel="nofollow" target="_blank">NUMARK CUE is Atomix Productions software for NUMARK. It's equivalent to VDJ 4.
geposted Mon 19 Mar 07 @ 1:36 pm
I think from 4.2v of VirtualDJ you can add text.
Go to FX button - VIDEO EFFECTS - TEXT
geposted Mon 19 Mar 07 @ 1:47 pm
Thanks pdnmusic, I'll have to check that out.
geposted Mon 19 Mar 07 @ 3:47 pm
hope this helps...
geposted Mon 19 Mar 07 @ 4:12 pm
