Which is the best for audio quality internal or external soud cards , usb or firewire ... which brand or model is right now the best performer for virtual dj 4.2r for video... pls help.
geposted Wed 21 Mar 07 @ 8:14 pm
uhhhhhh......great question , but what do you have for a system ? is it desktop/ rackmount or laptop ?
what operating system ? also there are 2 types of firewire connection.......
geposted Thu 22 Mar 07 @ 4:09 am
I have a desktop. Rack mounted in a server case.
750 Watt Power supply Win XP pro
Home built clone 6 fans on case 1 on cpu 2 on chipset which is an nividia nforce 5 chipset
AMD 64X2 dual 3800 chip
7gigs of corsair DDR2 at 533mhz
ASUS M2n32 deluxe SLI PCI Express with on board wi fi Motherboard
500 gb sata2 maxtor 11,000 rpm drive
PCI Creativelabs Xgamer Live 5.1
Nvidia GForce FX 6700 PCI express 512 mb DDR2
Virtual DJ Pro REV 4.2r
Hercule DJ console MK2
with the Vestax VCI 100 on the way to replace the mk2.
So i want to buy the best quality card for sound..
geposted Fri 23 Mar 07 @ 12:23 am
looks like a good system.......not familiar w/ the chip........ you should have few or zero driver problems with xp pro so get what you like........ i recommend at least 3 stereo pairs output
geposted Fri 23 Mar 07 @ 12:49 am
I have a Delta 66 on my home computer it has 4 in-puts and 4 out-puts so if you ever want to use the timecoded CDs It will work with this. It also has a brake-out box with 1/4 inch plugs for better quality.
I mostly use mine for multi-track recordings, but the times I hooked it up to my VDJ it worked fine.
You may want to get some more oppinions before buying, their may be something newer out there.
geposted Fri 23 Mar 07 @ 8:21 am
Problem with video card
Having VDJ Output to a monitor(Plasma or Video Screen) causes a conflick with VDJ.
Example
When Loading a deck with video. The video Image will take over the whole laptop screen.
And will also show the video on the output monitor, as should be.
The Image as it is playing locks itself on the laptop screen not letting you get back to VDJ
A cold shut down has to be done to restart VDJ.
This happen every time a video is loaded.
Is there a way to correct this using the 256 Nvidia Geforce Go 7900 GS Video card.
Computer Specs:
XPS M1710 Dell Laptop
Intel Core duo proccessor T7400 2.16Ghz/667MHz
2GB Shared Dual Channel DDR SDRAM
100GB 7200 SATA Hard Drive
256MB NIVIDA Geforce GO 7900 GS Video Card
Example
Computer Specs:
geposted Thu 29 Mar 07 @ 3:12 pm
