Topic: Video Mixing(Video Stops
haz0rdPRO InfinityMember since 2006
I don't use the video mixing feature so I thought I would try it out
Works great... but I have one problem/Question
While mixing the video stops, Music continues to play but the video stops
and kinda pulses sometimes. I don't have any effects turned on.
Is it my video card? I don't have anything fancy
Anyway.... The video continues whenever it feels like it.
if It will move also if I scratch the video from the icdx.
Any ideas?
geposted Fri 23 Mar 07 @ 4:22 am
What are the machine specs? What video card? Do you have anything else running in the background? What are your video configurations?
geposted Fri 23 Mar 07 @ 5:03 am
Probably your video card doesn't support hardware acceleration.
geposted Fri 23 Mar 07 @ 6:07 pm
Dell Laditude D620 Duo Core 1.6 GHZ
256Megs Video Ram
Intel(R) Graphics Media Accelerator Driver for Mobile Report
Report Date: 03/25/2007
Report Time[hr:mm:ss]: 16:50:18
Driver Version: 6.14.10.4446
Operating System: Windows XP* Professional, Service Pack 2 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 1014 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 224 MB
Graphics Memory in Use: 11 MB
Processor: x86 family 6 Model 14 Stepping 8
Processor Speed: 1662 MHZ
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel(R) 945GM Express Chipset Family
Video BIOS: 1264
Current Graphics Mode: 1280 by 1024 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
* Monitor *
Monitor Name: Plug and Play Monitor
Display Type: Analog
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 13.3 inches
Vertical: 10.6 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
832 by 624 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (70 Hz)
1024 by 768 (75 Hz)
1152 by 870 (75 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
* SDVO Encoder Report *
** Encoder 1 **
Vendor ID: Silicon Image
Device ID: 170
Device Revision: 3
Major Version: 1
Minor Version: 1
* Other names and brands are the property of their respective owners.
geposted Sun 25 Mar 07 @ 11:52 pm
sbangsPRO InfinityMember since 2004
thats a shared graphics card not many shared graphics can cut video mixing
actions need to happen a lot faster than just playing a video or a game
geposted Sun 25 Mar 07 @ 11:59 pm
Ok I kinda Figured that was my problem. I didn't expect the built in Dell Video Crap would do the video mixing well. and since the audio continued to play and the CPU usage was low I didn't think it was anything else...
Now here's the million dollar question...
on a laptop how would I get a better video card?
usb? pcmcia?
Thanks,
geposted Mon 26 Mar 07 @ 1:16 am
geposted Mon 26 Mar 07 @ 1:17 am
unfortunately these will be slow aslo
and the largest card i can find is 32 mb which is to low anyway :(
idealy need 256 dedicated memory or greater,
geposted Mon 26 Mar 07 @ 11:34 am
