Has anyone any ideas on why my VDJ starts up and displays a message telling me my Direct X isn't working properly and then when i click ok (no other choices) i get a message telling me the skin i am using is too big for my screen resolution and the display is masive (chosen one on config is correct) then it switches itself back to the correct resolution of skin and then i am able to load tracks on both decks yet they will not play!
regards.
DJ Gigilo.
regards.
DJ Gigilo.
geposted Fri 23 Mar 07 @ 1:35 pm
check your sound config options this is caused by bad settings on it
cofirm your settings apply and restart vdj :)
geposted Fri 23 Mar 07 @ 2:22 pm
cheers for the advice sky...
nice one bruva!
nice one bruva!
geposted Fri 23 Mar 07 @ 2:39 pm
sorted
i forgot to set up the soundcard to 4.1 iinstead of the default 2.1 setting, going to try it now and see whether it works or not...
stay tuned!
DJ Gigilo.
stay tuned!
DJ Gigilo.
geposted Fri 23 Mar 07 @ 4:38 pm
