how to get back " bpm length comment" i
i had to reformat my drive, but i backed up my virdual dj folder is the info i need in there i have tried copying the data base files with no look.
geposted Fri 23 Mar 07 @ 1:55 pm
what this vista mpx3?
geposted Fri 23 Mar 07 @ 3:30 pm
VirtualDJ Database (owner) XML is the one you need for Ver 4.2.
If you have the other xnl file I would also plug that in as well.
geposted Fri 23 Mar 07 @ 4:31 pm
