I had a lighted mini keyboard which I really liked. It is USB connection.
Does anyone know of one that is not USB, and where to purchase it?
Lighted one that is.
geposted Fri 23 Mar 07 @ 4:36 pm
im not sure if you can get light up ps2 ones because it draws the power for the light over usb.
geposted Fri 23 Mar 07 @ 4:40 pm
That's true, you need the USB to supply the power to light the Kbd.
geposted Fri 23 Mar 07 @ 5:33 pm
which was?
geposted Fri 23 Mar 07 @ 5:35 pm
Here's one
geposted Fri 23 Mar 07 @ 7:56 pm
pdnmusic:
It was a Zippy.
Man & His Music:
That's the one I did have. All of a sudden it just wouldn't work on either of my systems. But it worked on other systems. I was trying to see if there was one that was not usb.
Thanks for responses.
It was a Zippy.
Man & His Music:
geposted Sat 24 Mar 07 @ 1:39 pm
the USB zippy keyboard works perfectly with a $2.00 usb to ps-2 adaptor...
That's what I use now... the light is electro luminecent film... it doesn't use any power...... you could run that light for a year on a 9 volt battery....
get the zippy off ebay.. cheapest, and best lighted mini in my humble opinion...
only thing is.....
zippys are extremely sensitive to liquid spills.... a single drop won't affect a regular keyboard, but it can put a zippy out of commission until it's dry......
always keep an extra keyboard in the trailer...
only thing is.....
geposted Sat 24 Mar 07 @ 4:17 pm
Yep really do like the zippy keyboard. However the adapter will not work for me. Tried it on 3 systems.
geposted Sun 25 Mar 07 @ 2:06 pm
ive gone through 2 of these zippy keyboards just cause they got knocked off of the dj stand!!
theyre good for the fact that they light up so you can see them in a dimly lit club, and good for the fact that theyre small.
but ive found an even smaller kayboard. its not lit up, but this one is usb and i can use it with just my thumbs, like a mobile phone.
its available at maplin
click here
click here
geposted Sun 25 Mar 07 @ 9:25 pm
