I know that the current version of my vdj is limtied to 5 mins play bt I'm willing to work with that till I purchase
I have a problem with my setuop right now
I connected the TT output to the MK2 and ouputs 1/2 to channel 1 and 3/4 to channel 2 on the mixer.
Set it up as ASIO and click use external mixer
When I'm playing I get BOTH songs on channel 1 and DECKB on channel 2
How do I only get DECK A to be channel 1 and DECK B to be channel 2?
Also when I quit VDJ and check the settings in the MK2 it goes BACK to WDM and use external mixer is unchecked
I tried reinstalling the driver and vdj but no luck.
The faders work on the MK2 but it seems that all the outputs go to Output 1/2 rather than DECK a on 1/2 and DECK B on 3/4
It recognises the TCVs. I click autoconfig and everything works fine. It is playing/scratching etc but can't mix
Any suggestions?
Thanks
Any suggestions?
Thanks
geposted Sat 24 Mar 07 @ 2:43 pm
geposted Sat 24 Mar 07 @ 3:27 pm
Yes I looked at that before I posted, and I saw someone with the same problem and yuo replied but that didn't work for me
OK here's what's happening now and I'm not sure if this is how it's supposed to work.
When I move the fader on the MK2 to Deck A I get DECK A on channel 1 and Deck B on Channel 2.
But when the fader is in the middle I get both DECKS on cahnnel 1.
So I'll live with that until I find out what I'm doing wrong.
Oh my MK2 config screen is different from the ones you showed. Mine is a light blue screen with only symbols, no words
Thanks
Thanks
geposted Sat 24 Mar 07 @ 4:47 pm
have you installed the latest updates? for mk2?
and do you have the mk1 installed because if you do this will conflict.
geposted Sat 24 Mar 07 @ 7:01 pm
OK It may be the MK1. I just d/l the latest driver but same problem.
However when I went to the control panel I saw the icon for the MK2 AND the MK1.
It's not in add/remove programs or program files though, just the icon is on the control panel
I remember what happened now.
When I got the MK2 I put in the MK1 driver file by mistake and it started installing but it didn't find the MK1 (cause I had the MK2) and aborted the install
However, it seems as though some files still remained
How do I uninstall it?
If I have to reload the computer that's not too much of a big problem but if there's an essier way I'd appreciate it (even if I have to go into the registry)
Thanks
Thanks
geposted Sun 25 Mar 07 @ 1:32 am
i think the best bet is to reinstall windows
geposted Sun 25 Mar 07 @ 3:02 am
As norway would say, "hehe ;)"
I know a MUCH better option, but I won't say it.
It's so easy that it's like shooting fish in a barrel at this point. =)
- VT ConQuest
(Visual Turntablist)
geposted Sun 25 Mar 07 @ 3:14 am
mm
geposted Sun 25 Mar 07 @ 3:21 am
skyfxl wrote :
mm
mm?
geposted Mon 26 Mar 07 @ 12:07 am
yes decidedly mm
geposted Mon 26 Mar 07 @ 12:08 am
Oh!
...mm...
I thought you were usng mm in another context, as in ethical hacker speak. ;)
=P
...mm...
=P
geposted Mon 26 Mar 07 @ 12:52 am
Actually.. as a user of both PC and Mac I'd rather the Mac (it is a much better option. <- FULL STOP .. let's not drag this anymore).
And I may have a little knowledge in what I say .. my full time profession is software development (business solutions) and IT consultancy. So I've seen what both can do. I've been to many trade shows and have done business with both platforms.
I'm just waiting for the bugs etc to be ironed out and released and I'll be on that bandwagon (I want the VDJ for video mixing so hands down ...)
But in the meantime I'm using the PC version which I also like. For my purpose (hobby) it works.
Thanks for the input
geposted Mon 26 Mar 07 @ 1:38 am
=D
skilla wrote :
I'm just waiting for the bugs etc to be ironed out and released and I'll be on that (Mac) bandwagon
Glad to hear it.
See you on the Atomix Mac forums after VDJ/VV Mac is released! =)
geposted Mon 26 Mar 07 @ 2:30 am
I decided to download the trial version b4 I reinstall
Guess what, it works fine.
So there may be a problem with the consle software or it's settings
Thanks for the help
Thanks for the help
geposted Tue 27 Mar 07 @ 12:59 pm
Maybe something on the configuration, take a look on here just to know what could it be:
http://www.virtualdj.com/forums/66806/General_Discussion/DJConsole_MK2_MP3_-_Vista_update.html?page=4
geposted Tue 27 Mar 07 @ 9:43 pm
I'm not sure if that's justVista related. I'm notrunning Vista
I'm curious as to the problem so I'll keep diggin
Thanks again
Thanks again
geposted Thu 29 Mar 07 @ 1:30 am
