Im very interested in the TCV setup....How does it work exacly.....and what turntables work with them??
Cheers
geposted Mon 26 Mar 07 @ 6:43 pm
Any turntables work with it, as it's the actual record, not the turntable that is important.
The timecoded vinyl plays an audible signal, sounding very much like a fax signal, which contains data. The data is played into the laptop through the soundcards input, and Virtual DJ uses the data to map the exact location of the needle on the record. It then matches the position on the track you load to the position of the needle on the timecoded vinyl.
geposted Tue 27 Mar 07 @ 1:16 am
