Forum: Old versions
Topic: HDJC Mk1 + Mk2 together?
NebulaPRO InfinityMember since 2004
I was wondering what I could do with my old DJC now i've got a mk2, and came across the idea of using both of them. It'd probably kill off my power since they're fairly USB power intensive but could it be possible to use one console for decks 1-2 or 1-3 and the other console for decks 3-4 or 2-4 (where decks 3 and 4 donate to the second instance of VDJ, left being 3 and right deck being 4)
Is that possible? I think it'd be kinda fun and It'd stop people having a spair console :o)
Nebula
geposted Tue 27 Mar 07 @ 6:56 pm
Its possible, but you need to map in manually (map as midi devices manually in controller tab, choose enable midi and NOT the hercules console).
The also should be on different usb ports.
geposted Tue 27 Mar 07 @ 9:49 pm
Ooh! Ok, thanks. Ill give it a try when I have a free day :o) Thanks
geposted Tue 27 Mar 07 @ 9:52 pm
