Forum: Old versions
Topic: Maya 44 usb working with vista...
Hi all,
just in case anybody was wondering, vista seems to work with the maya 44 usb, provided that you use the asio4all driver.
www.asio4all.com
i kept getting errors when I tried to install the maya drivers (but they are meant for xp!)
Haven't tested it properly yet, or tried it with timecodes, but so far seems to work fine!
geposted Wed 28 Mar 07 @ 3:09 am
sbangsPRO InfinityMember since 2004
good news :)
geposted Wed 28 Mar 07 @ 11:46 am
dj_jrgPRO InfinityMember since 2005
Today i installed vista home premium on my vdj laptop. i can confiim that TCV will work with Maya44USB + asio4all driver v2.7
geposted Sat 07 Apr 07 @ 2:39 am
Cool, but just incase anybody's interested, I managed to get the windows xp drivers to work on vista as well, incase you feel more comfortable using the ones that came with the hardware
geposted Sun 08 Apr 07 @ 6:54 pm
apopsisdjPRO InfinitySenior staffMember since 2003
geposted Mon 09 Apr 07 @ 3:03 pm
Even better, thanks for that!
geposted Tue 10 Apr 07 @ 4:24 am
i am using the new v2.85 in vista, but does anyone know how to get to the control panel?
geposted Sun 29 Apr 07 @ 1:02 am
As far as I can tell, you can only get to the control panel through virtual dj. There's not a stand alone application any more (That i can find anyway!)
In virtual DJ, just click "config", go to sound setup, select maya 44 usb ASIO driver, then a button appears for asio options i think. Click on that and you get to the control panel.
geposted Sun 29 Apr 07 @ 4:19 pm
ahh thank you, found it =)
geposted Sun 29 Apr 07 @ 8:27 pm
