I've got VDJ installed on my laptop with no problems (which is nice!),
but now I've made a second partition, because the first one has lots of other programs on, etc.
The strange thing is that on the orignal partition VDJ runs at about 4% cpu when it's idle.
But on the new partition it sits at around 20% when it's idle.
I guess that there's some tweak i've made with the first installation that i haven't made with the second one, but I can't think what. :(
Just to finish the story, I've just re-formatted the second partition and put vista on it to since i heard that vista is better with videos. All seems to be fine, but still a higher cpu useage when its idle.
Any suggestions what I might have forgotten?
Thanks. :)
Thanks. :)
geposted Wed 28 Mar 07 @ 12:39 pm
check this
http://www.virtualdj.com/blog/CoolioNoob/blog2634.html
and
http://www.virtualdj.com/forums/64699/PC_Version_Technical_Support/SELECTED_SOFTWARE_GUIDES.html
i diodn't do allo f them just about 2/3 of all the tweaks but my laptop ZOOMS
also. this thing is AWESOME! it controls and maximizes cpu speed and useage.
http://www.diefer.de/speedswitchxp/
and
geposted Wed 28 Mar 07 @ 9:06 pm
Thanks. :)
Thanks. :)
On my backup work PC, the PCU was working too hard after a bunch of updates. Turned out to be something with Windows media Player 11. I rolled it back to 10 and the PCU consumption goes back to normal
geposted Wed 28 Mar 07 @ 9:59 pm
Thanks for the input guys. I'll give them a go.
geposted Wed 28 Mar 07 @ 10:42 pm
