Does anyone know if the Dac-3 and the Gigaport AG are compatible with Windows Vista ?
geposted Wed 28 Mar 07 @ 10:48 pm
DAC-3 will work fine. There are no drivers yet for the Gigaport. I'm anxiously awaiting those as well. I emailed ESI in February and they said the drivers are in progress but no release date is available.
geposted Wed 28 Mar 07 @ 11:14 pm
Hi, I've got the DAC-3, definately the easiest part of installing vista! Just plug it in and off you go.
Also, I don't have a gigaport, but I've got a maya 44 without vista drivers. I've managed to make it work using the asio4all drivers.
You can get them from here:
www.asio4all.com
It's not a perfect fix, but it might be worth a go while you wait for the proper drivers.
www.asio4all.com
geposted Thu 29 Mar 07 @ 12:41 am
