Forum: Old versions
Topic: Video Window????????????
Video Card
Sapphire Radeon X1600 PRO PCI Express 512MB DDR2 Video Card w/TV-Out, DVI & VGA
I have asked this question before and didn’t fix the problem so lets try again…
I have two monitors,, one for VDJ software and the second for video/Karaoke…
First, Desktop is extended,,, software is open,,, I open the video window….. I move the video display window to the extended monitor.. All is good so far…..
The video window is my problem…. The very top of the video window,, not the monitor,,, I not familiar with what this bar is call so please bear with me,,, at the top of the video window there’s a display bar that extends across the video window.. On this bar we have to the LEFT, (VirtualDJ Video) If you click on this area of the bar a pull down appears with Restore, Move, Size, Minimize, Maximize and Close to pick from….. To the Right side of the bar you have three square boxes,, Minimize, Maximize and Close just like you find on any window… When I select full screen the video window opens to full screen BUT that bar is still there… I don’t want the bar there.. Is there a way to remove the bar so the video display extends from edge to edge …
My other problem is that the video window will not stay at full screen… I select full screen on the video window,, the video window opens to full screen for about three seconds and returns to the original size…
Thanks
geposted Thu 29 Mar 07 @ 1:40 pm
First - in your video card settings you have it set to dual video and in the Display Properties - Settings tab when you click the Identify button you get a 1 on your main monitor and a 2 on your second monitor correct?
If that is the case - run VirtualDJ - go to the Config - Video Tab - From the 'TV Output' Drop-down choose the RADEON X1600. Make sure hardware acceleration is checked. In the options section make sure 'Activate on Load' is checked. Click OK. Now play a video and you should see it immediately display on your second monitor.
That did it ... thanks
Your welcome.
