what is a good cooling pad for my hp pavillion notebook (9010 model) i noticed it is running hot when i'm using cue and it freezes after about 4 hours of play. it will freeze if i'm going from folder to folder looking for songs. but if i make playlist it won't freeze. i tried everything else. the only solution is heat. so help me out pros. oh one more thing if i start out going from folder to folder it will freeze in about 2 hours but if i use my playlist for about four hours it will play with no problems untill i start going from folder to folder.
geposted Thu 29 Mar 07 @ 6:50 pm
i use this companys cooling plate it takes heat away from the laptop into the plate
http://www.xpad4laptop.com
geposted Thu 29 Mar 07 @ 7:06 pm
are you sure that the x pad will do the trick is this really better than using fans?
geposted Thu 29 Mar 07 @ 7:20 pm
i think so , usb laptop coolers can damage ur laptop :(
i have had a bad experiance in the past with i one i acidentaly knocked it with gear , and it snapped one of my usb clean of the board fortunately this was insured:)
geposted Thu 29 Mar 07 @ 7:24 pm
ok i will give it a shot.
geposted Thu 29 Mar 07 @ 7:27 pm
i'm a huge huge huge fan of this thing
http://www.kingwin.com/pdut_detail.asp?CateID=41&ID=208
SD card readers, USB hub, three big fans for an absurd cooling technique, fan speed control and on-off switch... great build quality i thought too.
geposted Thu 29 Mar 07 @ 10:11 pm
I prefer buying a stand to lift the bottom of the laptop, rather than a cooling pad. Much better results in my experience.
geposted Fri 30 Mar 07 @ 6:21 pm
