Hi I have 2 technics 1200 mk2 turntalbes a dell inspiration lab top and bought a gigaport ag soundcard. I hooked up the two turntables to the gigaport into the outputs white 1 red 2 and the other turntable white 3 and red 4. Then I connected my mixer channel 1 to the gigaport in output white 5 and Red into 6. Finally I have my mixer channel 2 into the gigaport White into output 7 and red into 8. I then connected my speakers to my mixer output. Is this set up correctly. When I go to config in VDJ4 and set the imputs to timecodes Outputs to external mixer and soundcard is asio. Under ASIO driver it says Gigaport Ag Asio driver. Everytime I click ok or go to asio config I get this error Error in Asio Sound Driver Not Enough Channels if anyone can help my please let me know. Thanks alot
geposted Fri 30 Mar 07 @ 1:08 am
i,m not sure about it but as far as i know gigaport ag has 8 analog outputs and non inputs.
for using tcvs tou will need 4x4 souncard wich means 4 inputs and 4 outputs.
you conect your tts to the inputs channels and you connect the outputs to your mixer.
soundcards like that is maya 44 and u46 dj.
http://www.esi-audio.com/products/maya44usb/
http://www.esi-audio.com/products/u46dj/
sory but i dont think that tcv will work with your souncard:(
geposted Fri 30 Mar 07 @ 10:00 am
Gigaport DON'T has 2 STEREO LINE INPUTS, so it's useless to try to connect 2 turntables in there.
You can use another soundcards, look in the hardware forum for the recomended ones...
geposted Fri 30 Mar 07 @ 7:52 pm
You can't put a in to a out, unless she....nevermind.
geposted Fri 30 Mar 07 @ 8:09 pm
