Forum: Old versions
Topic: 3 turntables
Hello i'm new using vdj and i would like to know if is possible to use 3 turntables instead two. Is there any skin for that?
And one more thing, now im usin the pc version (trial ver) and im thinking in getting the mac one. I would like to try it before so will be a trial ver soon?
Thanks
geposted Fri 30 Mar 07 @ 2:47 am
Please any answer, it's easy
Thanks
Thanks
You mean use 3 decks or 3 turntables?
Yes, i mean use 3 virtual decks or turntables. Possible?
Thanks
Thanks
Sorry, I looked into it an i dont think its possible.
I know on the PC you can run more than multiple instances (2 VDJ's ), giving you 4 decks at once.
Thanks anyway.
I think that thing should be solved in the mac platform.
Let me know if there is any new about it.
Thanks!!
edubayo wrote :
Thanks anyway.
Thanks!!
I'm sure this issue will be addressed in a future Mac version.
Afterall, the Mc version is only less than 2 weeks old. =)
This is definitely a feature that turntablist duo and/or turntablist bands (3+ performers) would want.
- VT ConQuest
(Visual Turntablist)
