hey,
do i lose everything (like my cues and my comments) if i reinstall 4.0 and get rid of 4.3?
i have to copy something right...the library or something from the program files...
how do i do it to avoid doing everything all over again?
geposted Fri 30 Mar 07 @ 10:55 pm
copy
virtualdjdatabase.xml
virtualdjdatabase(yourname).xml
mp3database.txt
out of
C:/programfiles/virtualdj/
reinstall then put them back:)
mp3database.txt
out of
geposted Fri 30 Mar 07 @ 11:02 pm
And make a backup of them, you never know when you gonna need them ;)
geposted Sat 31 Mar 07 @ 3:18 am
hey,
thanks....just did that...it all saved but i ended up losing my keyboard shortcuts...
not a biggy though
thanks guys
not a biggy though
thanks guys
geposted Sat 31 Mar 07 @ 5:09 pm
for future reference forgot about those sorry,
you can save your prefered controler midi mapping configs and keyboard shortcuts on
the keyboard shortcuts tab look for save
and on the midi tab the same :)
save them to another folder to load them go to "load"
on each of these menus
geposted Sat 31 Mar 07 @ 5:34 pm
More accuretely, make a zip of all your VDJ folder :)
It wil include playlists, skins, etc.
geposted Sun 01 Apr 07 @ 12:08 am
smart idea i like :)
geposted Sun 01 Apr 07 @ 12:26 am
you're welcome, it is a pleasure mate :p
geposted Sun 01 Apr 07 @ 3:42 pm
"""" DJ BK1
hey,
how do i do it to avoid doing everything all over again?"""
How come you want to go back to 4.0??? is there something wrong with the new update?
hey,
geposted Sat 07 Apr 07 @ 5:37 pm
no there isnt.
geposted Sat 07 Apr 07 @ 6:06 pm
skyfxl wrote :
copy
mp3database.txt
out of
mp3database.txt
out of
geposted Sat 07 Apr 07 @ 6:07 pm
Then why does he want to run a older Ver. ?
geposted Sat 07 Apr 07 @ 8:24 pm
