Forum: VirtualDJ Skins
Topic: Need help or idea to make an hidden slider or other trick
Hello Skin Team,
i'am a stupid newbie by creating vdj skin. ;-)
Today it's my first skin tests. But it's very cool.
I need help.
I want to make an textzone which displays me the "pitch".
I'am make an slider over which textzone (sam position and size like the textzone).
I would make an hidden slide over which textzone. But when i slide.... the texzone the slider (is a black graphic position) is paint over :-(.
So i tested it wih an transparent graphic in my bmp file. But the transparent graphic is ingored from vdj :-(.
Hase anybody an idea how can i realize an transparent/hidden slider.
Here is my work example
*gain level des tracks*
<textzone chan="1">
<size width="60" height="30"/>
<pos x="447" y="331"/>
<text font="TAHOMA" size="30" color="#CCFF00" align="center" format="%Plevel"/>
</textzone>
*slider/actions für das gain level des tracks*
<slider action="gain" chan="1" orientation="round" dblclick="reset" rightclick="auto">
<fader sensibility="4000">
<pos x="100" y="100" nb="1"/> *this is the black pixel but black is shit and transparency dont work :-(*
</fader>
<clipmask x="447" y="380"/>
</slider>
Pleeeeaase help me and many greatings
HAWK
geposted Sat 31 Mar 07 @ 1:22 pm
Hawk, Try this
</fader>
</slider>
DJ Mykel
Hi DJ Mykel,
many thanks it works fine. *yeaahh* thx thank ;-).
But i have the next question ;-)
How can i make an button with 2 actions
I want to make an textzone as which displays cue point.
I try to make an button which due 2 actions leftclick set cuepoint and right or dblclick go to my cuepoint. But why only works the right button. Which make i wrong.
My idea was to make an button1 for leftlick action and an button2 for right click action.
I not understand the skin tutorial
<button action="" chan="" value="" rightclick="" dblclick="" leftclick="" pannel="">.
Which values can i set to the rightclick="" dblclick="" leftclick="" vaules??.
Thanks for help or idea
It isn't possible to have 2 functions on a single button, but it does sound like action="hotcue" may help you with the feature you want.
Hope to see you as a registered user soon :D
DJ Mykel
What do you mean with hotcue? I don't found anythong about this in the skinnig tutorial.
2 Actions not possible? :-(.
Okay i accpt it :-( ..... ;-) but i'am failure already by simple taks :-(
I want to make an button action on an left click.
My work example
<button action="edit_cuename" chan="1" value="1" leftclick="auto">
<size width="70" height="20"/>
<pos x="18" y="367"/>
</button>
...lefcklick="1" not work righclick="0" lefcklick="1" not work. Which values muste i use.
To bring the edit_cuename command to front?
Can you make me an example for use an button action by dobbelclick
and an button by leftclick?
"Hope to see you as a registered user soon :D"
-->yes i will buy me an virtual dj console and so i have an home edition soon *yeeah*
And for this i will made my own skin. Only for me ;-). In the meantime i mus live with the demo version of vdj
Greetings
HAWK
Hotcue is another command (although I am not sure if it is valid in 3.4).
The SDK is the most useful guide, but I suggest you open the default skin XML and try to copy/edit some of the functions from there. This will give you a great aid in understanding the functions of the codes.
leftclick is similar to value, and therefore you can leave that out in your example.
doubleclick is often used to "reset" (sliders, knobs, etc)
Mykel
