Can anyone outline the setup that is needed to record a video mix directly to a dvd recorder? I have tried Fraps, but it is just not working for me. When I try to record with the hotkey, it does nothing.
So if anyone can tell me what I need to make it work onto a DVD recrder, that would be great!
Thanks!
Thanks!
geposted Sat 31 Mar 07 @ 2:59 pm
you either need a vga/dvi converter box to get you the s-video or componet input to the recorder. But hopefully you have one already on the back of your video card. If thats the case all you have to do is enable that output. But only problem is if your vid card is like mine, you won't be able to view the projector while that output is on. But u will still be able to see the master output through the monitor.
geposted Sat 31 Mar 07 @ 6:01 pm
