Topic: Shuttle Advise / Input Needed
Would like some input from shuttle users and others familiar with shuttle systems.
I will be building a shuttle system in the next few days and would like to know if any of you see any potential conflicts with the following hardware being used. Any input and or advise will be appreciated. Thanks.
Shuttle:
http://hq1.shuttle.com/products_page03.jsp?PLLI=7&PI=189
http://www.newegg.com/Product/Product.aspx?Item=N82E16856101004
Processor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103759
Video Card: Would like definite input on video cards with this shuttle box.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130071
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121034
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121025
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150189
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130074
Ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134012
geposted Mon 02 Apr 07 @ 8:35 pm
i think you should contact mp3jrick mon
he built mine.... and i have no problems whatsoever
geposted Tue 03 Apr 07 @ 3:08 pm
Thanks dreadlox.
geposted Tue 03 Apr 07 @ 4:50 pm
I have to tell you that that's the perfect machine!
I would go with this card that you listed http://www.newegg.com/Product/Product.aspx?Item=N82E16814130074
because #1, truthfully, anything over a 128 mb video card is overkill for video mixing... but just get a 256 for good measure. and #2. you can't use a double space card in the shuttle... it has to be a single space card.
other than that, that will be the most jammin' system you've ever put your hands on...
-Steve
geposted Tue 03 Apr 07 @ 5:16 pm
Steve L-
Nice recommendations, the Shuttle PC's are looking quite attractive.
The eVGA cards are built solid and should be able to handle any of the current video content we're using.
Ever have any heat issues due to the compact design of the case? Is everything able to cool properly?
-Woody
geposted Tue 03 Apr 07 @ 6:47 pm
Thanks for the input everyone. I appreciate it.
geposted Thu 05 Apr 07 @ 5:51 pm
