Out of curiosity, can anyone tell me what the pitch resolution is for TCV's and TCCD's in terms of % pitch? I know the Pioneeer CDJ-800 has a 0.05% pitch resolution, while the CDJ-1000 has 0.02%. How does VDJ timecode compare?
geposted Wed 04 Apr 07 @ 5:34 pm
The timecode follows the hardware, so its the hardware that decides :)
With a CDJ100 you have 0.02% and with a CDJ800 you have 0.05% accordingly
VDJ internally has 0.01%
geposted Wed 04 Apr 07 @ 5:38 pm
Oh yeah you're right -- in the case of TCCD's it must be determined by the hardware...
But for TCV's then, it's 0.01%? Since TT's are analog..?
geposted Wed 04 Apr 07 @ 5:58 pm
yes, in theory... But some turntables have better pitch sensitivity than others..
The better pitch analogue pitch slider, the better sensitivity..
The better the hardware, the better will the timecode control be :)
geposted Wed 04 Apr 07 @ 5:59 pm
Makes sense... Thanks as always for your help DJ-in-Norway!
geposted Wed 04 Apr 07 @ 11:09 pm
