I have seen some postings about Itunes ... where it seems like it freezes on the star up logo when you select yes to import Itunes Files...
It is not frozen. It is doing the import, just let it sit there for a while, and VDJ will open.
geposted Fri 06 Apr 07 @ 2:44 am
Virtual DJ is no longer asking me if I want to import my iTunes playlist when I start up. Why is that?
geposted Wed 18 Apr 07 @ 10:49 pm
Once you select an answer in the beginning, it won't ask you again at start up. I believe once you select yes, you see a "music" folder in the browser, and it is like a "short cut" to the itunes music, so if you add new things, it will automaticly be added to VDJ.
geposted Thu 19 Apr 07 @ 4:25 am
on mac
APPLE + CONTROL CLICK ON LOCAL DB or folder list
press import itunes
On windows
Right Click any where on the folders lists and press import intunes
press import itunes
On windows
geposted Thu 19 Apr 07 @ 11:45 am
