Im having a little trouble setting up virtual DJ.
I have 2 Stanton 150's and ESI U46DJ.
I have tried multiple ways of setting it up.
I have done straight into the U46Dj then to mixer, Ive tried using y splitters, nothing works.
Someone with these tables or the knowledge help me out with the setup.
greatly appreciated.
geposted Fri 06 Apr 07 @ 6:06 am
First of all your turntable has Selectable Phono or Line Output.
Select phono output.
Use 1-2 and 2-4 inputs of your souncard to conect your turntables.
Then 1-2 and 2-4 outputs of your soundcard to conect to your mixer.
then select on sound set up 2 timecodes inputs and 2 outputs to your mixer.
Select asio u46 souncard.
Go to time code confiq and on advance view.
Before you press auto confiq make sure that your 2 monitors channels on u46dj control panel are muted.
Press now auto confiq and after that UNSELECT SOFTWARE PRE AMP FUCTION.
geposted Fri 06 Apr 07 @ 1:36 pm
Hang on.
You told him PHONO or LINE. But then you said to turn software pre-amp off. The only time you would take it off is if your using PHONO which uses the hardware pre-amp.
So. Let me explain more clearly for you.
If you select PHONO. That uses hardware pre-amp which is built into the sound card. So you must untick the USE SOFTWARE PREAMP option.
If you select LINE. That does NOT use hardware pre-amp and requires you to have USE SOFTWARE PREAMP option enabled/ticked.
geposted Fri 06 Apr 07 @ 8:58 pm
u46dj dont need software pre amp.
i get 100 % percent signal only if i untick software preamp and i have u 46dj and sl1200 mk2 wich have phono outputs.
geposted Fri 06 Apr 07 @ 9:46 pm
