The my sound cards is the EDIROL FA-66,
The ASIO can't normally use,
Excuse me, how does the ASIO normally work?
Thank
Thank
geposted Fri 06 Apr 07 @ 6:56 pm
I don't have this card, but let's try this. I will assume you have loaded the drivers, if not do so. Open config in VDJ>sound setup>outputs. Select the one that best suits you. Go to sound cards, select ASIO, select ASIO config tab. In the ASIO driver window, you should see your card listed. Pick the config that you want in the output channel window.
As I said, I don't own this card. I am not sure if you are suppose to use their drivers or not. I have noticed that some times, it is not good to use the mfg drivers. Maybe some one with this card will come along to help you.
geposted Fri 06 Apr 07 @ 8:31 pm
Thank A Man and His Music
I chose the FA-66 orotund playing cards in the ASIO, but system hint:"Error in the ASIO driver"
But this orotund playing cards be that the qualities is goods
geposted Sat 07 Apr 07 @ 5:52 pm
