hi there.
I ve got strange noises under volume,each channels,crossfader...bass,mid and treble!Is it sound card?Or smth else!Plz help,coz u can clearly hear it after recording,at playback!
Thnx
Kissglobal
Thnx
Kissglobal
geposted Sat 07 Apr 07 @ 3:49 pm
hi
i think i have the same but mine is wenever i move bass/mid/treble/crossfader basecally anything i do while a song is playing even wen i am playing around with the next song i can hear a deep rumbling sound also i get it if i use my external mixer or my faderfox my pc works fine witth tracktor dj but i dont like using that program i think virtual dj is better but tht noise stops me from using it , when i record u can hear tht sound it cant be my sound as its a new one and it does it on my other soundcard as well. any help i would love!
geposted Sat 07 Apr 07 @ 6:55 pm
I am having the same problem on both my PC's ever since the 4.3 upgrade. I hear a click click sound in the background. I got lucky with one PC this past weekend and shut it down 3 times and it went away but today it is back again. I don't understan why this program has become more unstable with each upgrade? Also, I cannot run in 1080X720 format since day 1 three years ago without the screen after an hour going black! Hey guy's what's up?
geposted Mon 09 Apr 07 @ 4:23 am
Yes i have this problem aswel, sounds like a groaning or rumbling sound whenever i use my control desk.
Im running windows XP SP2
AMD Authentic 1.4 ghz
768 ram
Soundblaster Live (for master sound) and onboard VIA AC'97 (for monitor)
Hercules MK1
768 ram
Hercules MK1
geposted Tue 17 Apr 07 @ 1:57 pm
Hi guys
I don't know if this is related with your problem but I also had a rumbling noise when i used my laptop, just by luck I tried another laptop with same version VDJ and the noise went away, later I find out that the AC mains adaptor was the problem, after looking around for different makes I use a HP mains adaptor and works fine, the funny noises are gone.
Good luck
Good luck
geposted Tue 17 Apr 07 @ 11:42 pm
