Is there anyway to get rid of the Annoying video window
that pops up when you use the ICDX .
It pops up for sure if you press the paremeters knob but it also pops up sometimes
with the job wheel... It just gets in the way and the only way to close it is to disable video
in the options.. but sure enough before the end of the night it will come back again.
geposted Sat 07 Apr 07 @ 10:05 pm
Known bug, being researched as to why it happens for potential fix in v4.4
Do you use a MIDI controller as well?
Also, are you using just 1 iCDX or 2?
--Read here to learn more --
http://www.virtualdj.com/forums/62752/Hardware_Technical_Support/Backspin_with_ICDX_activating_VDJ_Video---__causing_crash.html
geposted Sun 08 Apr 07 @ 5:30 am
It's a bug in VDJ. I know it's being researched cuz I also have 2 icdx. Even with the midi disabled, it still pops up but not as often. Using 4.0 or 4.1 seems to be the best alternative now.
geposted Sun 08 Apr 07 @ 5:20 pm
I have 2 ICDXs and I am using 4.3 but it does not stop the show. just kinda annoying
geposted Sun 08 Apr 07 @ 6:54 pm
I am running two iCDXs also and using 4.3 Cue it only happens rarely and never stops the music. I just close the window.
geposted Sun 08 Apr 07 @ 8:58 pm
