Topic: Vocal Effect causes hangup in VDJ
Just wanted to know if anyone else had this problem
Both decks going
instrumental on deck one, a song on deck two with Vocal effects on (Voice only)
if you try to scratch the side with effect active (with a scratch pad) I tried on icdx and hdjc
it hangs up and the music kinda studdas for a few seconds then continues to play..
I was able to repeat this every time.. can someone else try I want to know if it's my computer.
geposted Sun 08 Apr 07 @ 7:04 pm
its because of the way the effect was coded, the effect only works effectively in when going forwards.
hmmm ok, wont use that anymore.
I usually just kill the bass. I will go back to doing that.
