Forum: Old versions
Topic: Sonique Codec Needed
I cant play the Sonique video effects, when I look under C, Program Files, VDJ, Video Effects, I can see a list of them all but windows can not recognize the file
Is there something special I need installed to play these in VDJ??
geposted Mon 09 Apr 07 @ 3:00 am
Figured it out....sorry!
Nzack, what did you do?
The rest of us may benefit from your acyiuons.
Thanks.
Bryant
Hardware Acceleration has to be on in order for the visuals to play in VDJ.
When I looed at the Sonique files in (My Computer) (C) (Program Files) (VDJ) (Video Effects) it was empty, I had to copy and past all the Sonique files into that folder in order to play them in VDJ.
They were locate in another folder thats why I could not play them, there was nothing there when I clicked on the "Open" box in VDJ.
Another thing, I assumed Windows XP would recognixe the SVP file these are encoded in, thats not the case, only VDJ has the Codec installed in the program to "identify" and play all the files...I think there are 78 different video effects.
