I was helped a bit and changed my crossfader to the left and right arrow keys. but by doing this I lost my nudge (I'm thinking this is the same as pitch bend.) I began trying to assign a key to the nudge command but could not find out how to select the proper key. I thought about assigning the up and down arrow to nudge + and Nudge -, I'm sure you might have some suggestions. LIke the comma key as Nudge + and period key as Nudge -, I just couldn't get it to give me an option to select a key and assign it a command. I know its something simple. thanks MIchael Aka, Playing music before running water.
geposted Mon 09 Apr 07 @ 8:29 am
NUDGE shortcut
turntable >> nudge >> value +256 & value -256 (for + and - keys that you want)
Let it be on default deck as the deck vaule.
Hope that helps;)
geposted Mon 09 Apr 07 @ 5:58 pm
if you need more info on keyboardshortcuts check out my blog :)
geposted Mon 09 Apr 07 @ 9:32 pm
