Hi all,
I've got a bunch of digitraxx remixed video clips with intro like funkymix etc... problem being I can't get it to play clearly in vdj. I was able to play these clips flawlessly b4 on my older laptop but they just not playing right on the laptop im using.
Basically the image gets all confused and gets pixalated with and sorta goes into a shadow sorta movement. Kinda hard to explain... lets just say its f$%#d up.
I've just upgraded to vista and all other formats like mpeg2 and vob work perfect. I'm also a bit confused on how you know what codec vdj is using when you select video decoder under the codec options in vdj.
I think the videos were encoded with media player v08 codec. Tried selecting media player under codecs for asf format but it just continually says its loading? I play the videos under media player and the clips are fine...
Any word of advice appreciated..
geposted Mon 09 Apr 07 @ 10:49 pm
