Topic: VDJ vs CUE
Since they appear to look absolutely identical, is there any advantages to making a change or not? Are they just that....the same?
Is the Total Control unit a stepped up/beefed up version of the Hurcules controller? Could using Total Control plus a Maya44 eliminate the need for an external DJ mixer since Total Control would control crossfade as well as pretty much everything else and the sound would still be coming from the Maya and TCV? (sending the audio out from the Maya to powered speakers)
geposted Thu 12 Apr 07 @ 8:45 pm
its a totaly the same
the total control is like herc but by numark
you woudlnt need a mixer if you used it with the maya it is just a controler and has no soundcard however
yes it would work like before
kind regards
simon.
