i have a hercules/dj control mp3 system and when i want to start virtual dj and use my system this come's up on the screen
error in the ASIO sound driver
geposted Sat 14 Apr 07 @ 8:44 pm
me too on that one. I have Pro tools, Fruity Loops and Reason they all work with the ASIO but not this program. I am not mad but I would like to know if it can be fixed.
Thanks.
Thanks.
geposted Wed 18 Apr 07 @ 3:34 am
my console switches straight back to wdm, how do you get asio to work?
geposted Wed 30 May 07 @ 3:27 pm
please add your serial
geposted Wed 30 May 07 @ 4:09 pm
set it to asio after loading vdj then set it to asio mode in options
what version do you use?
geposted Wed 30 May 07 @ 4:10 pm
Not available in Home edition? Vers 3.2 is it? The version that ships with the Mk2's.
Boo
Boo
geposted Tue 05 Jun 07 @ 1:26 pm
It is available for pro i think for the timecoded thingy but i think DJC also can be use but for limited time. Maybe someone can comfirm this, It been a while since i use the djc version. As for to set the Asio, U must set it at the hercules control panel to asio mode before u start VDJ. Then at the config, select hercules asio. Btw the version 3.2 is old now for DJC is 3.4. Get the update at the download area. Cheers
geposted Tue 05 Jun 07 @ 2:31 pm
