so I am playing 2 tracks and when I go to listen to track 2 in my headphones to make sure its right...it records what i heard to the audience or on my recording...how do I sample the upcoming track without anyone else hearing it?
geposted Sat 14 Apr 07 @ 11:27 pm
So you are saying that it is "playing" the music of whatever channel you have the headphones set to?
Check your settings and make sure you have the channel selected for 1/2 3/4 correctly. One will be your headphones (for example channel 3/4). You want to then hook your line going to the board into your 1/2.
I honestly have to fool with it every show for some reason. Just try switching the channels around a bit to find out what works.
geposted Sun 15 Apr 07 @ 6:25 pm
