Forum: VirtualDJ Plugins
Topic: playing a generic video while playing audio tracks
mintersPRO InfinityMember since 2006
hi
is it possible to play adverts or some other media (ie video files) through vdj when you have audio only files playing.
thanks
dave
geposted Tue 17 Apr 07 @ 12:49 pm
hi,
Unfortunately it's not currently possible to play generic videos automatically while audio files are playing. (Although it is a much requested feature, hopefully it will be implemented in a future update of the program).
It is possible, however, to have a image slide show appear (could be adverts, photos, etc) automatically every time an audio file is played.
Alternatively, visualisations can be displayed automatically, these are similar to those you find in media players like winamp, etc. where an abstract pattern moves in time to the music.
Hope that helps.
geposted Wed 18 Apr 07 @ 3:23 pm
If you really wanted to play some generic videos, you could use a multi-instance skin of VDJ (like vmix 5.2 multi-instance) and then you can play the generic videos with no sound in one instance, and the audio files in the second instance.
geposted Wed 18 Apr 07 @ 3:26 pm
thanks for the reply
geposted Thu 19 Apr 07 @ 2:16 pm
