Help!
Everytime I try to change parameters in the midi mapping section, the [value=0] box changes to a [relative scale=0] box
how to a set it to leave it at [value=0]??
thanks!
thanks!
geposted Wed 18 Apr 07 @ 3:47 am
ok - got that part sorted (i think)!
BUT
does anyone know how to map the pitch blend buttons +/- to the buttons on the X-session?
I tried, but it ended up doing some weird things, like permanently holding the pitch + down (even though i selected temporary), and not working for the - pitch
help!
BUT
help!
geposted Wed 18 Apr 07 @ 9:44 am
I'd love to know that, too. I have the X-session pro and i was unable to map for pitch-bend.
geposted Wed 18 Apr 07 @ 10:35 am
anyone? :(
geposted Wed 18 Apr 07 @ 11:51 pm
wow, i can't believe no one has the answer to this question!
geposted Fri 20 Apr 07 @ 12:35 am
Final plea! Anyone?
geposted Sun 22 Apr 07 @ 4:23 pm
Sorry, I use the X-session but it don't use it for pitch bending... I will try to map it out and see if I can help...
Joe
Joe
geposted Mon 23 Apr 07 @ 2:14 am
go in config, enable midi click config, load midi_xsession. then find (cross fader ) move the cross fader back and forth and it should pick up the signal...them push ok and go check and see if the fader moves on the screen. The part i'm stuck on is the headphone part. How can I hook my head phones up?
geposted Fri 11 May 07 @ 5:51 am
