Forum: Old versions
Topic: DJC nad VirtualDJ 4.x
Hi i jst go thte Dj Control MP3 and it works great with the software that it came with BUT i like the pro version better, in fact im trying the trial right now. After opening it for the first time I noticed that the Dj Control doesnt worK with the software. Is there any settings I need to change?
thanks guys
geposted Thu 19 Apr 07 @ 5:24 am
If you click on the "config" button (top right corner)
Then click on the "remote control" tab
There's box for "hercules DJC", under that click the "enable" tick box. There's also a few other options there you might want to look at.
You might like to know that if you buy the pro version you can download a plugin that lets you set the buttons, etc on the djc to any action you like in virtual dj.
Hope that helps.
