Forum: Old versions
Topic: M2k Shortcuts
Hey Guys,
im still learning how everything is set up. But is it possible to set up the volume controls on the M2K to control the pitch instead of volume? thanks in advance
geposted Thu 19 Apr 07 @ 10:30 pm
Yes you can, when you go into the config menu
select the Tab remote control, there you will see the options for the mk2 (dj console), there is one check box that says invert pitch/volume, that should do the trick.
Mindtwister3d
awesome thanks!
