Forum: Old versions
Topic: IRQ Issues (i think)
Hi!
I've downloaded the trial version of the VirtualDJ and I think i have a IRQ issue with my sound card. The sound is cracking bad, with all performance settings in VDJ. I Noticed that there is probably a conflict with my integrated soundcard and few other devices. But the thing is I can't change the IRQ's of these devices. I have XP professional that won't let me change the IRQ with device manager (suprise!?). BUT the real problem is that in BIOS i can only see 15 IRQ thingys, and the conflict is in IRQ value 23 (WHAAT!?) So have anyone solved this kind of problem, I really need help.
My computer:
AMD 3700+
2Gb ram
7900gt
Soundblaster live 5.1 (no conflict)
Realtek AC 97 (conflicts with ATA driver and USB driver)
geposted Fri 20 Apr 07 @ 6:52 pm
Ok now I got the soundcard to a different IRQ value, but the sound is still cracking. Can the devices cause cracking if they are not soundcards but are in a same IRQ value? If not, any guesses what is wrong with my computer?
please read my blog on this issue , it contains info on how to change irq safely
click my name to view it
aslo ensure you are using the latest demo
Don't use internal sound cards with VDJ. It demands more than those crappy built-in ones.
Yes I have the latest demo version. I got rid of the cracking sound, but I think my soundcards are off sync. After about 10 minutes of listening you can notice that the speakers are something like 1/8 of a beat foward than the headphones.
I think I'm gonna get a external soundcard maybe maya44, will VDJ work with it well?
