Forum: Old versions
Topic: Hercules MK2 - headphone issue
I recently bought a Hercules DJ Console MK2 and it came with the old version of virtual dj (which was upgradeable to v3.4) after I registered the software. I would like to upgrade to the new version, but when I use the trial version 4.2, the headphone switch/option to listen to Deck A and Deck B do not work. The headphone mix selection works but nothing can be heard on either channel A or B for cueing. The old version works great. Is there anything in the works to fix this problem or a trick to make it work as this seems to be the only problem? All other controls and functions seem to work. Has anyone had this problem? Ideas? Thoughts?
thankz
geposted Sat 21 Apr 07 @ 8:33 pm
for 4.2 you must choose
input : none
output : headphones
card : mk2
1/2 main 3/4 headphones
