Forum: Old versions
Topic: Recalling Multiple Loops
I haven't used Virtaul DJ in over a year. There were some features that were missing and I chose not to use the program. Now, I'm back to see if I can make it work for me.
I noticed there is a recall loop function that recalls the last made loop. I also know that there are unlimitted Hot Starts. Here are my questions:
If you create a loop and then start the song from the beginning of the will it automatically start looping for you when you get to that point in the song?
Also, it doesn't seem like there are multiple loops and recaled allowed. In a traditional CD player and now in the Denon HD-2500 you can store 2 loops that will automatically loop when they are reached. I would think that Virtual DJ should allows at the very least 2 of these as well, if not more.
This feature is very important to me as it will be a major deciding factor between sending the Denon unit back and using Virtual DJ or sticking with an appliance based product like the Denon.
geposted Mon 23 Apr 07 @ 8:39 am
