Forum: Old versions
Topic: Numark DJ i/o
Hi, Seeing that the total control has no audio capabilities, is anyone looking at the DJ i/o sound card?
http://www.numark.com/index.html?http://www.numark.com/products/product_view.php?v=overview&n=181
_ USB 2.0 (single channel operation in USB 1.1)
_ Ultra low latency
_ 2 independent RCA stereo outputs
_ Microphone input with adjustable gain mixed to stereo pair #1
_ 1/4" Stereo headphone output on stereo pair #2
_ 24–bit audio, 44.1kHz and 88.2kHz sample rates
_ ASIO drivers with control panel
_ USB bus–powered (optional +6 VDC external power supply sold separately)
I am hoping its gona be Mac supported. Anyone know?
geposted Mon 23 Apr 07 @ 6:49 pm
Can support verify that this sound card will work with VDJ>?
it does.
skyfxl wrote :
it does.
Does it work the same way the MK2 does with audio?
I am referring to autocue the audio when you load a song into the next case player...
I am guessing this device is Numark's answer for Audio for Cue and the Total control controller?
the auto cue is in the options of vdj if you have 2 outputs like this does it will autocue if you wish it
yes it will
