Forum: Wishes and new features
Topic: Sample options
May be it could be useful to disengage "synch on" for samples. This way the jingles could start quickly (sometimes they are cutted cause it's hasn't started at the good time) (Sorry for my english)
geposted Thu 16 Sep 04 @ 4:04 am
Agree. It would be easy to add an option under "beat", "half beat" and "quarter beat" for example a "no sync".
Another massive improvement would be to be able to manipulate a sample same way as a vinyl; no scratching requiered though, but a nudge option would be welcome.
And maybe a small pitch slider for each sample, so we can turn off beatlock? :P (I know I'm asking too much, but I have to ;)
erXon
and the ability to preview sample thru headphones before playing I'd add.
you can easily turn off sync on beats for samples...
just make sure beatlock is turned OFF ;)
(uncheck beatlock in options)
if thats what u are looking for??
And you can configure your samples to play in preview mode
in advance config. the problem is you have to switch sound cards everytime so the sound doesnt play on your output.
Regards
Another problem with samples i sthat the options are not saved when VDJ is closed.
About samples, I observed that the shortkey does not work in order to augment or low the sound level.
Although there is option to do that, it does not work. We can only define a sound level between 0 and 4096.
I have a sample (example001) working good, but when i closed the program this sample (example1) no sincro fine again.
