I have the VirtualDj3 version 1.0 Dj Control Edition on my PC,and sounds very bed,sounds like the equalizer is geting kraizy or the lactenci is very hi....I put a M-audio sound card on my PC but wen I´m playing on the VirtualDj it sounds the same!!!Hellp me Please!!!
geposted Mon 23 Apr 07 @ 7:44 pm
You have free update for your console version here.
If you still have problems, write here your PC specs.
geposted Tue 01 May 07 @ 3:56 pm
I have had the same proplem with my laptop everytime I touch a wire for example it just goes hyper on me. The proplem your having is the Earth which is sensitive for some cases.
What I found the best solution is to use an adaptor. That should work.
geposted Thu 03 May 07 @ 10:10 pm
